MichaelW
- Build Rating
- 5.00 star(s)
So if you've already built the Echo Foxtrot from @vigilante398 DON'T BE LIKE MIKE and steal the EF86 tube from it to put in your Diplomat thinking that it pretty much does the same thing.....these are very different pedals and both their own thing going on!
This another one of Nathan's very cool new layout projects that is SO MUCH easier to build than the his Gen1 DIY PCB's.
Excellent layout, lots of room for components, low noise floor, and glorious tube sound!
This one according to Nathan is based on the EF86 channel of the Matchless DC30.
It's got a crap load of gain on tap, must be something like +20db at least. I barely had mine cracked. Perfect for pushing the front end of the an amp which is where this pedal shines. Compared to the Echo Foxtrot which I found to be better suited as a unity gain tone conditioner. The Diplomat BOOST like a MOTHER.
There's an 8 way rotary switch that selects different capacitors for tonal response. At the highest setting it can sound a bit like a treble booster, or at least it functions that way.
Lots of really cool useful sounds and excellent build!
Thanks @vigilante398 !!!
I painted the enclosure I got from Nathan a Fire Orange.
I used a Water Clear red LED and not too happy with it. Seems a little too dim. I'll probably go back in swap it out for a blue one or clear one.
In the demo I'm using my recently re-necked Tele Thinline. Falling in love all over again with this guitar!
Starting out using a clean amp to show the different tonal options on the rotary dial. Then I'm switching to a crunchy amp setting and pushing it with the Diplomat, which is where this pedal really shines in my opinion!
