Hi, I have just finished my first PCB build. However, something is not right.
First, when the pedal is bypassed, it's all good, I hear my guitar through the amp.
When it's engaged however, the LED doesn't turn on (and no sound comes out of the pedal).
I first focused on why the LED was not turning ON. Here is what I did:
- I measured the voltage at my 9V DC jack. It shows 9.41V, so far so good.
- there is continuity between the + and R31
- R31 reads 10K ohm
- there is continuity between the other leg of R31 and the negative leg of the LED (the square on the PCB)
- then there is continuity between the positive leg of the LED to the ground
- the voltage on R31 is 0V: I would expect the resistor to drop the voltage and to be 9-1.8V
I tried to compare what I listed above with what I see on the schematic attached below.
On the schematic, the positive leg of the LED is connected to R31, while it's the negative one in my case.
I am unclear if I misread something or wired wrongly.
I used my multi-meter to check if my LED was wired the wrong way, but I really think I have it matching the PCB symbols: in continuity mode on the multi-meter, I can light the LED if I have the black probe to the negative leg of the LED and the red probe to the positive one.
I really appreciate any help to understand what is happening. Thanks!
Cheers
- R31 reads 10K ohm
Cheers
