benny_profane
Does anyone have any recommendations for a tube headphone amplifier DIY project? A DAC isn’t necessary.
Also I think @vigilante398 had mentioned possibly designing a simple tube headphone amp, I'm not sure if there has been any progress on that.
I haven't committed to making a DIY project for it, but the headphone amp I'm working on is designed to be a practice monitor.@vigilante398 is your project an amp designed to be a practice monitor or for an audio system?
Can I interest you into wading into the world of hi-fi?I haven't committed to making a DIY project for it, but the headphone amp I'm working on is designed to be a practice monitor.
Probably notCan I interest you into wading into the world of hi-fi?
Well, let us know if you change your mind and take it a bit furtherProbably notthough to be fair most of my customers are bassists so in order to get a good bass frequency response I am already using hi-fi output transformers.
These two cover my experiences also—both builds were for friends. The Bottlehead projects are really good sounding; I was almost shocked at how good their phono preamp is. (And he used to make a small guitar amp that I am truly sad I didn’t get when they were available.) My current headphone amp is very solid state, and is fully balanced (like the rest of my stereo) but the Bottlehead was quite lovely through my HiFi man phones. (My DAC has both balanced and unbalanced outputs.)I built the Bottlehead Crack OTL and I love it. Fun to build, not too complex, plenty of mods you can do on it later if you get the itch, and it sounds great.
Edit: I also built the Project Starlight hybrid headphone amp, and while it sounded quite good, I could never get it to be very quiet whenever music wasn't playing, and I tried a ton of stuff to kill the noise. The Bottlehead is basically dead silent.
I'm thinking a bottlehead crack using one of vigilante398s power supply boards.
The HV daughter boards I sell definitely do not have enough current to supply a 6080 or 6AS7 tube. You're going to need a power transformer.A tube headphone amp is on my list for this year. I plan to get a pair of HD600s soon and I've heard they paper well with tubes.
I'm thinking a bottlehead crack using one of vigilante398s power supply boards. It would make it completely transformerless, affordable, and pretty small. It'll probably take a bit of modding to make it work but I've gotten decent at modding circuits in the past year.
For a little more money, Pete Millets Jonokuchi looks really nice.
Rob robinet also has a cool post for a headphone amp based on his micro champ
Good call, I didn't even check what tubes the crack uses. I guess I'll look into something 12au7 basedThe HV daughter boards I sell definitely do not have enough current to supply a 6080 or 6AS7 tube. You're going to need a power transformer.
My headphone amp uses a 12AU7 in the preamp and a 12BH7 in the power amp, and I'm powering it with a pair of SMPS, one for each channel. I had two of them at the NAMM show with me for people to test pedals so they were operating for 8-9 hours a day for 4 days and they held up well, no issues (except one of my NOS tubes going bad, sad day).Good call, I didn't even check what tubes the crack uses. I guess I'll look into something 12au7 based
Genuinely curious. Do you notice a difference in sound fidelity (or any difference) between the tube headphone amp and a normal headphone "amp".I built the Bottlehead Crack OTL and I love it. Fun to build, not too complex, plenty of mods you can do on it later if you get the itch, and it sounds great.
I feel like I did notice an improvement from the Project Starlight to the Crack. I remember listening to Led Zeppelin, which I've done for probably 2 decades at this point, and hearing all this extra detail. All the little squeaks and coughs and background sounds, plus the actual instruments just sounded better. I will say that I got nicer headphones around this time as well, so I assume it's a combination of factors.Genuinely curious. Do you notice a difference in sound fidelity (or any difference) between the tube headphone amp and a normal headphone "amp".
