Hello all-
Built a dream fuzz today, and forst tey everything worked…except for the LED. I used a 3pdt breakout board with LED. It didnt work, so I wired it to the motherboard spot, still doesnt work. Swapped the polarity just in case, and still no go. The LED works, tested on my multimeter. Do I need to jumper one of the LED spaces if I use the other? (If i use the motherboard LED space, do I need to jumper the breakout board, or vice versa?
The pedal sounds incredible, otherwise.
Thanks for your input!
