Hello PPCB, I'm a new joiner to the forum, but I've been working on my hobby of building pedals for maybe a year and half. Up to now I've used pre-drilled enclosures, but now I'm taking on my most ambitious project yet, and I'm custom UV printing the enclosures with custom drilling, courtesy of Tayda.
I'm a bit new to reading data sheets for components, and drilling in general, and I was hoping someone might pass their eyes over my workings and just check I'm reading the right number for the mounting hole diameter. I've put what I believe the correct diameter is in (mm):
https://www.taydaelectronics.com/6-35mm-1-4-mono-insulated-switched-socket-jack-solder-lugs.html (11mm)
https://www.taydaelectronics.com/mini-rotary-switch-1-pole-8-position-alpha-rs16211-20mm.html (9.1mm)
https://www.taydaelectronics.com/mini-toggle-switch-1m-series-spdt-on-on-short-lever.html (6.4mm)
https://www.taydaelectronics.com/dc-power-jack-2-1mm-round-type-panel-mount-1.html (8mm)
Since I will be using powder coated enclosures, the Tayda instructions suggest adding 0.2mm to the measurements. I also intend on mounting a 3mm LED flush with the enclosure for aesthetic reasons, and so I'm planning on adding a 3.2mm hole, and probably hot gluing the LED in place.
If anything I've written seems stupid, I would appreciate any guidance that will put me on the right path. Thank you!
