DSP Program selector for FV-1 projects 16 programs
Note, the Octagon and other projects already have a rotary program select knob. A simple diode array is used rather than an 8 to 3 encoder IC.
I found out that the FV-1 has 8 built-in algorithms in addition to the 8 in the eprom... so for a 1 of 16 selector, you could use an up-down button to drive a 4 bit counter or similar (e.g., like https://www.ti.com/lit/ds/symlink/sn74f163a.pdf).
So many possibilities for sure. :)
I'm working on an FV-1 module specifically to be embedded into projects like the program selector, presets, etc....
And of course, that will eventually be followed with a main board to support it.
