I was wondering if it is possible to wire a dual mono guitar pedal to true bypass each board with one switch? It's for a synth so toggle switch not a problem. Bit of a newb
true bypass requires the ability to switch the IN and OUT lines for each board so two switches are used. turning the LED on and off when the switch is pressed requires a third on/off switch, so a pedal switch normally has 3 sets of switches.
if you did not use one switch for an LED, you can use a 4 pole double-throw switch to provide separate in/out switching for two boards.
