Joben Magooch
Apologies if this exists somewhere already but I wasn't able to find anything beyond the 'standard' dual pedal wiring options found on the Wiki.
So, on some dual pedals nowadays builders have started making them with either two TRS jacks or four jacks to allow you to use both sides of the pedal independently in a switcher or to insert a pedal between the two sides or so on.
Analogman offers the "4-Jack Option" as an upcharge on the King of Tone. Instead of just two jacks for I/O...you guessed it. There's four. If you plug into the outermost jacks it functions just like a typical two-jack pedal. In through the first side of the OD, into the second side of the OD, output. But there's also the option to use one pair of I/O for the Yellow side and another for the "Red". If you use a looper/switcher of some sort, you can control both sides independently as they're effectively operating the same as two separate pedals.
Another example is the Browne Protein. It uses TRS jacks to accomplish more or less the same purpose:
(Of course there are plenty more examples I'm sure, these two just came to mind first)
The former seems like it would be fairly straightforward with switched jacks or similar. The latter I'm not so sure of. Does anybody know of an easy way to accomplish this? Perhaps with a small toggle switch (rather than a dip switch, as that of course wouldn't be part of the standard PCB) or something.
I'm sure it'd be simple enough to do a dual enclosure and just box it up like two separate pedals (four jacks) and then just jumper them externally if you wanted it the "normal" Side A>Side B configuration but it'd be a little cleaner IMO to do it either the internal way or even better still with just two TRS jacks. Anyone have any ideas and/or wiring diagrams to accomplish such a thing? Thank you!
If you use a remote switching system, or want a pedal or pedals between the two sides of the KOT, you might want separate inputs and ouputs for each side. We can offer a four jack Ver4 option for $50 on a new pedal or $75 as a mod. You can still use two jacks like the normal KoT and go through both sides. The jacks are "normalized" so when you plug into just the two outer jacks, the signal is routed through both sides just like a normal KOT.
The TRS plug on the input is going to act as the loop for the green side.
The TRS plug on the output is going to act as the loop for the blue side.
Tip is the input/send from your Loop
Ring is the output/return to your Loop.
There are two dip switches inside the pedal that need to be flipped down to the “split” position to use it this way. Remove the four screws from the back panel and flip the switches to the down position.
