To the OP... Second jack from the left in your pic needs to be mono switched, NOT TRS... TRS will just ground out either the "B" input or "A" output, depending on how you wired the jack.
You need one of these:
Attach output "A" to the "switch" lug, "B" input to "tip" lug...
Hope this helps...
EDIT: OK, I may be late to this one! I saw your other post that says "solved"... Sorry for the redundancy!
