geekmacdaddy Well-known member Jul 13, 2019 #1 Happens in bypass and coincides with the rate knob. Could I ground it out with the stompswitch from a lug on the rate pot? Thanks
Robert Reverse Engineer Jul 13, 2019 #2 Has this happened on all of the ones you've built, or just this one? Upvote 0 Downvote
geekmacdaddy Well-known member Jul 13, 2019 #3 possibly all 3, definitely 2 of 3. happeining on both sides too. of course could be my fault, such a crazy build. Upvote 0 Downvote
Robert Reverse Engineer Jul 13, 2019 #4 Try moving the wires around that go to the In/Out jacks and see if that makes any difference at all. Upvote 0 Downvote
geekmacdaddy Well-known member Jul 19, 2019 #5 Brilliant! The lead dress around the rate pot is the culprit. Moving the wire did the trick. Thank you so much Last edited: Jul 19, 2019 Upvote 0 Downvote
geekmacdaddy Well-known member Jul 19, 2019 #6 Think I'll try shielded cable there. Upvote 0 Downvote
bergera Member Jul 20, 2019 #7 good to know and glad you got it fixed. It's on my short list of stuff to build Upvote 0 Downvote
geekmacdaddy Well-known member Jul 20, 2019 #8 bergera said: good to know and glad you got it fixed. It's on my short list of stuff to build Click to expand... Go slow. Upvote 0 Downvote
