untamedfrontier
Hey gang, long time no see. Decided to finish up a Duocast that I've had 90% done for over 2 years this morning and I've run into a bit of a weird one.
Effect powers on, passes signal, works (sort of, it does drive/fuzz), but both the effected audio and LEDs are pulsing/flashing. Flashing only occurs on Strymon Zuma power supply, but does not occur with another known good Duocast build, so can rule out power supply as the issue, but is interesting to note that the indicator light for the channel on Zuma also flashes at same sequence, so would appear to be some sort of overvoltage issue? Flashing on power supply happens regardless of if the effect is engaged or not.
I've built both a duocast and simulcast previously, so I'm scratching my head on this one. Would love any suggestions
Things I've already attempted:
- Swapped out LT1054 with known good in other duocast; only change was the LEDs were lightly pulsing and after change to known good are flashing.
- Checked if DC jack were faulty, no change with a different known good DC jack
- Thought toggle switch may be shorting against the adjacent pot, but no change after ensuring they weren't touching.
- Swapped transistors with one from known good Duocast; no change
- checked my multimeter on a few things, but had no idea what i was looking for.
- reflowed connections on switch and nearest pot to switch; no change
- double checked 3pdt wiring and no observed shorts or misconnections
