playedincanada
Greetings!
To be honest, I'm a bit stumped.
I've built this pedal many times and never come across this problem. No sound? Yes. The fix on that was reflowing the solder on a few places. Cold Solder joints seem to be the bane of most pedal builders existence and usually one of the first problems to come up.
So I'm familiar with that. I also, a long time ago broke a potentiometer because I tightened it a bit too much when putting it in the enclosure. Snapped it in half actually.
I encountered this problem a couple of weeks ago, but just got around to trying to troubleshoot it.
The problem is simply this --> The pedal works as it should, the gain trim pot, the low cut, volume for the lower gain side and the volume for the higher gain side. However, if I flick the switch to put the pedal into 27V as opposed to just 9V, the pedal begins to oscillate, very much like how a Devi-Ever Hyperion II might when it's "crazy" is turned up. It's a low octave/signal that bounces around. I mean, it's cool, but I want the pedal to operate as it should.
I have reflowed all of my soldering. Checked the cabling and whether the IC/Chargepump is put in the right way.
The only other forum post I've seen where someone had a similar problem, the builder said they turned down the gain using the trimpots until it stopped squealing. Mine's not squealing, it's doing crazy fuzz/octave stuff. I also remember seeing that someone posted that they had a faulty/broken switch so they switched it out and their problems also went away.
I desoldered the switch, thinking it might be because it's an "amazon special". However, I put in a nice Taiway switch and it didn't make a lick of a difference.
Has anyone encountered this problem as well and found the cause? Or does anyone know enough of the tracing of the circuit to know why it might be doing that and what I should be checking next? I even resoldered the legs on Transformer.
I could test another IC to see if the IC itself is faulty since I used a socket, so that will be my next step.
Thanks in advance.
Thanks in advance.
