DuoPhase LFO no LFOing
Aentons
All voltages look good but neither of the yellow LEDs are lit. All trimpots set at noon. All the TL072 came from Mouser. Signal is passed in bypass and effect. A weird thing I noticed when putting it together was the led negative pad was square rather than the positive but they are marked with A and K so I checked the schematic to verify and used the letters.
Any ideas what I should check?
Do you have any 1054s on hand?
I don't think the 7662 you have in there will deliver enough current
I don't have any others to try.
I have a TC1044SCPA on the A side and a TC7662BCPA on the B side. There is no change when reversing which side the chips are on.
All knobs and trimers set to roughly noon. Toggles set to down toward stomps. Looks like IC 2A may have some issues. Here are the voltages using a Onespot.
Edit: I mixed up pins 1-3 on IC1B but it's corrected now
IC1 A. B.
1) 0. 0
2) 0. 0
3) 0. 0
4) -7.79. -7.55
5) 0. 0
6) 0. 0
7) 0. 0
8) 8.96. 8.97
IC2 A. B.
1) 7.74. 0
2) 3.86. 0
3) 0. 0
4) -7.78. -7.55
5) 0. 0
6) 0.8. 0
7) -6.15. 0
8) 8.96. 8.97
IC3. A. B.
1) 0. 0
2) 0. 0
3) 0. 0
4) -7.79. -7.55
5) 0. 0
6) 0. 0
7) 0. 0
8) 8.96. 8.97
IC4. A. B.
1) 0. 0
2) 0. 0
3) 0. 0
4) -7.80. -7.55
5) 0. 0
6) 0. 0
7) 0. 0
8) 8.96. 8.97
IC5. A. B.
1) Var. Var
2) Var. Var
3) Var. Var
4) -7.80. -7.55
5) 0. 0
6) 0. 0
7) 0. 0
8) 8.96. 8.97
IC6 A. B.
1) Var. Var
2) 0. 0
3) Var. Var
4) -7.80. -7.55
5) 0. 0
6) 0. 0
7) Var. Var
8) 8.28. 8.25
IC7. A. B.
1) 8.96. 8.97
2) 5.22. 5.27
3) 0. 0
4) -3.18. -3.10
5) -7.81. -7.55
6) 4.14. 4.15
7) 5.45. 5.52
8) 8.96. 8.97
IC8
1) Var
2) 0
3) 0
4) -7.55
5) Var
6) -6.14
7) -6.14
8) 8.25
Here is a closer look at the IC2A area. Sorry about the scars but my edge cutter has developed a bur I need to file down. I don't think of them are deep or severe enough to cut a trace.
After the holidays, Its been slow going with this. Using an audio probe, I managed to get the A side working. The B side, no so much.
With the audio probe I get strong phasing on IC2B.1 pin3, but its mute on pin1. On pin2 I get a really loud squelchy sound and I can not quite figure it out. I took the socket out and cleaned up the pads and soldered a new ic straight to the board. No dice
I tried taking IC3B out of the socket and direct soldering a new chip. No change.
The green shows where I get strong phasing. The pink is no sound at all. In the red, there is a high pitch squeal that oscillates with the LFO. The yellow is a mid range buzzer sound with no oscillation. The voltages are all stable single digit mv on pins 123,567. So strange.
I got frustrated and put this thing in a box and let it sit for a long while. I pulled it out today did an audio probe and jumpered the trace where the audio stopped. Wha-La, it's working now.
