Effects Layouts Break Action with Relay Bypass
pnggolf22
Greetings all,
Hopefully this will just be a quick confirmation that I've got the right idea for wiring this up. I love by Break Action but want to add relay bypass in order to switch on and off bypass with the relay ports on my MC6 Pro midi controller. I believe the attached diagram should be correct, but I would really appreciate a fresh set of eyes checking things out just to confirm.
Thanks!
did you get this to work? This sounds interesting.. I have an MC6pro on my board as well
I haven't gotten it fully working. When both sides are on it works perfectly, but when either or both sides are off I have no bypass sound. Unfortunately I haven't had time to troubleshoot to figure out if I did something wrong, or if it's just not compatible.
