Big Monk
Thanks!
Checked it before and wasn't updated yet.
So If I got it right you kept the parallel resistor at 10k and you decreased the series resistor to 6.2K. Correct?
Yup. Here is the problem: The Rate LED is naturally, by nature of how it's connected, not going to be as bright, ever, as the normal LEDs. Dropping the series resistor too low makes the pulses less robust and distinct and maximum brightness is very low to begin with. I played around with a number of values and found 6.2k to be the brightest and have the most distinct pulses.
I then went back and changed the LEDR values for my main LEDs. The bi-color is fine but if I were to go back in, I'd change the bypass LED to something even higher.
A good thing to do might be to tack in the Rate LED first, with the circuit operational and leave the speed and bypass LEDs until last. Take a breadboard and set up all three in a row and tweak the LEDR values until they match to your desired output.
