For the trim pot to set the wet/dry signal levels for better phasing, I am going to omit R16 and R17 and put a 200K trim pot in the board, each outside leg on the non-common side with the middle pin going to the common side.
Understood. Are you suggesting there is not enough control for the 200K trim? Not as fine detail as the 50K trimmer, but I suspect it will be fine for dialing in the balance. Much cleaner install on the board.The whole point of the fixed resistors and smaller trimpot is for better control of the balance.
Thanks. I will see how it works out. Easy to see that there is much more control with the other combo, and I may switch to that after I give it a go. BTW --- did you sub the 10U caps for the 1U in your build? And do you think you can hear a difference with them?Yes. If you were trying to hit the broadside of a barn I’d say use 200k and no fixed resistors but you are targeting complete cancellation which means the right balance. A tight balance at that.
Definitely do what you want but I think the mod is better served with fixed resistors and a smaller trimmer.
Keep in mind that other combos would work as well: 91k resistors and 10k trimmer, 82k resistors and 20k trimmer, etc.
As an anecdote: I had a 500 ohm trimmer on the power rail of my Protoboard for fine adjustment of voltage and it was a nightmare. Couldn’t hit consistent target voltages for shit because of how large (relatively) it was compare to the normal < 100 ohm series limiters on power in.
Anecdote of an anecdote: There are at least 3 threads I found in my Vibe research from DIYSB and everyone who tried what you are going to was less than pleased with the control they had over the mix.
Thanks for all the work you put into researching, testing, and laying out the mods so clearly on the documents. Those were big factors in deciding to go ahead an put together the electrovibe board.
@Big Monk -- looking at your diagrams, did you think about turning the bicolor LED into the blinking rate light as well? Looks like you could power the bicolor LED from the C14 point and have serial resistors on each of the separately switched ground wires. I may give that a try.
Sounds nice!My rate LED is separate.
The design I’m working on now ditches the Bi-color altogether for separate diffused Speed indicators.
We need to bring back the LOVE/LOL emojiI was gonna post this but I wasn't sure how @zgrav would take it, but it's too good not to post. Hope you got a sense of humor Z.
What to say, Hmmmmm.. ROTFLMAOI was gonna post this but I wasn't sure how @zgrav would take it, but it's too good not to post. Hope you got a sense of humor Z.
Which 1uf electrolytic caps did you change to
10uf? AND what does it do exactly?
