I don’t quite understand what they were developed for but the just was the HFE changes when exposed to light….. I haven’t put them in circuit yet but I assume they do not emit light and only react to it…Basically they were top quality OC71’s… not bad for a 1.50 each for a nice germaniumWow. That looks interesting. Maybe this is a dumb question, but do they light up at all when amplifying a signal or anything?
No, they do not emit light. Rather, they are directionally sensitive to light.Wow. That looks interesting. Maybe this is a dumb question, but do they light up at all when amplifying a signal or anything?
Intriguing concept there. I imagine with an LFO driven LED up against and pointed at the correct spot on the OCP71, a fuzz could be toyed with.Can you control the fuzz with an LFO? That would be interesting.
I'm thinking white light LEDs would be optimal for OCP71s. Back when OCP71s were made, LEDs did not exist and they had only natural and bulb lights to work with. Still, experimenting with different colored LEDs is warranted as an investigatory exercise. I just ordered 10 from what appears to be a reliable UK seller.UV/IR clipping diodes bent and sandwiched between the two gain stages is where my head goes.
Could try it with some reds and water clears of course. Idk what spectrum these would react to...
Easy enough to test.
Then you have an "Original Design Reactive and Dynamic Germanium Fuzz" you can sell for $7000 that's a big muf with half the diodes pulled out(ignoring NPN/PNP).
I've thought about this with LDRs on emitters but never gotten around to toying with it.
What spectrum were they originally designed to react too?I'm thinking white light LEDs would be optimal for OCP71s. Back when OCP71s were made, LEDs did not exist and they had only natural and bulb lights to work with. Still, experimenting with different colored LEDs is warranted as an investigatory exercise. I just ordered 10 from what appears to be a reliable UK seller.
I found this highly rated seller on eBay, ordered 10 of them myself just yesterday and already received a shipping notice. Claims to have more than a few.Would anyone care to post or PM me a reputable supplier?
