Ok, revisiting this one a bit. Got a UV print back from Tayda and, yeah, the template was completely off. Got tired of messing with it so...decided to just create a rough facsimile of the original. It's not exact but does at least have the same components and gist of the original. Thoughts? If y'all like it, I'll finish it up and post the templates here.
That pedal looks great awesome job!! I haven't started putting mine together yet. Still deciding if I should make one more attempt to get the enclosure right. I believe I've managed to figure out mostly everything I was doing wrongNow, I will say that this one had a mishap as well. Somehow I didn't realize that the LED connection was at the top and not the bottom of the PCB. The drill template lied.
I went ahead and updated my template a bit. Moved the LED position, enlarged the logo a bit, and fixed the positioning of the labels. The PDF version is set and ready for uploading on Tayda or wherever you get your UV printing done. Feel free to update and/or modify it as you wish.
Dropbox
www.dropbox.com
Dropbox
www.dropbox.com
Yeah you can add .2 to the hole diameter to take care of that, but that paint really needs to come out anyway, I us a small round file or my drill pressFinally my 5th enclosure is a success. The holes needed to be sanded a lil bit to fit the parts through but besides that its great
View attachment 19402 View attachment 19403
I love it! It may actually even look better then the original heheHoly shit, CHRIS! Your pussy is HUGE!!!
This turned out so much better than I expected. Thank you brother for sharing your hard work. It's magnificent.
| JUN 14, 2022 |
