Good morning,
I finished my first build (Chela - Talons clone) yesterday and not to my surprise it’s having issues. Even bypassed the effect create considerable high frequency hum, that significantly drops when engaged. When engaged I get sound, but it’s very muddy especially when I try to add in gain. The EQ sections seem to slightly work but not as they should.
I tested components before assembly and did a thorough visual inspection of both sides of the PCB before install pots, wires, jacks. If need to get those underside pictures let me know if it’s better to bend the pots up or remove them all together.
The main two things that i slightly modified were I got the 5 pin jacks and on my 9v, there was a 3rd pin that was for battery that I bent over so it wouldn’t touch anything else. Could these be the cause of the problems?
Here’s a video trying to capture how it’s acting incorrect
Let me know if there’s any other info I can provide and I’ll gladly do so.
Thank you so much
Thank you so much
