I see what you did there...Adjust to taste is always best, anyway.
I'll definitely give that a try... I've got another etched board lying around... and something in the pipeline as well...Bumping an old thread for more Frantone goodness. Reading through the FSB post above it looks like folks may have found a sweet (sorry, pun intended) spot with a low-gain NPN option in Q4. The comments mentioned a 2N3563 at ~70 hfe but maybe a 2N3903 would be a good alternative?
Oh man, will definitely be keeping an eye out for any updates/build reports!I'll definitely give that a try... I've got another etched board lying around... and something in the pipeline as well...
NTE2544? TO126 NPN Darlington.I don't think anyone has found anything on the FS25444 - it is absolutely unique to this pedal (or is a remarked something else).
Tagboard effects suggests it looks like the 2N5133 or ME4003 as it is in the old TO106 case style - so I was thinking about using NOS 2N5133
Effects Layouts suggests rounding up the usual suspects in place of the FS (whatever the heck): 2N5088, MPSA18, BC549C, etc.
Dunno - it might be a rebadged NTE...NTE2544? TO126 NPN Darlington.
Material of Transistor: Si
Polarity: NPN
Maximum Collector Power Dissipation (Pc): 10 W
Maximum Collector-Base Voltage |Vcb|: 120 V
Maximum Collector-Emitter Voltage |Vce|: 120 V
Maximum Emitter-Base Voltage |Veb|: 6 V
Maximum Collector Current |Ic max|: 1.5 A
Forward Current Transfer Ratio (hFE), MIN: 1000
Noise Figure, dB: -
Package: TO126
More likely that the NTE is a rebadged FSDunno - it might be a rebadged NTE...
Only reference to an FS25444 transistor I've seen is on a couple of aviation sites, but there was no data sheet.
