irvmuller Active member Jun 21, 2025 #1 So, the OG pedal can run on 9 and up to 24 volts. With the higher voltage comes greater headroom. Is this also true for the Frequency Interchange?
Nostradoomus Well-known member Jun 21, 2025 #2 As long all your caps are rated for at least 35v you're good to go. if you used the recommended 50v electros even better.
