SteveScott
Looking for some ideas on a mod for the Friendly Fire Fuzz to increase overall volume without changing the core sound.
Cool, I can get the 2n2222. Sorry though, what is an lbp 1?You could try different transistors of a more modern flavour, maybe a 2n2222 set in there. Or splice an lbp1 before the output.
LMGTFY
For all those people who find it more convenient to bother you with their question rather than search it for themselves.lmgtfy.com
Thank you!Yeah that’s weak.
An LPB-1 is an EHX Linear Power Booster, a super simple boost circuit not known to colour your sound. If you’re handy with vero they’re a breeze to make if you just need things to be louder.
Thanks Chuck. I'll give those a try. R1 is already 2.2m, would changing R2 (and possibly R4) help in the same way?Here are three things to try (in no particular order):
1) Increase R1. First, measure the collector voltage on Q1. For maximum volume, you want it near 4.5V. If it's significantly lower than that, and I suspect it is, increase R1. This will have the strongest effect when FUZZ is maxed.
2) Increase R3. First, measure the collector voltage on Q2. For maximum volume, you want it near 4.5V. If it's significantly lower than that, and I suspect it is, increase R3. This will have the strongest effect when FUZZ is dialed down.
3) Increase C6. This pedal has a huge mid scoop and that will suck the volume out.
4) Decrease C7. OK, four things.
The biasing scheme in this pedal, and it's not unique to this pedal, makes the performance very dependent on transistor beta (HFE). High beta transistors will need to have the bias resistors increased to compensate for the higher gain. High HFE is not always a good thing in vintage-style pedals.
Maybe you could have been more helpful with '' An LPB-1 is an EHX Linear Power Booster ''LMGTFY
Hey Chuck, sorry it took so long to get back to you. If I put my meter on what I believe is the collector and the base, it is reading 2.53v.What's the collector voltage with R1 = 2.2M?
