L lcipher3 Well-known member Sep 14, 2020 #1 Tayda doesn't stock A25k (the treble) pots - B25k or A20k - yes. Which is better to swap or do you really need the A25k? SmallBeard does - but ordering 1 pot is going to nail me for shipping
Robert George Cloney Sep 14, 2020 #2 Technically you could use an A50K dual pot (which Tayda does carry)... bend the second row of pins around and solder them to the first row. Certainly not ideal, but I'd be tempted to do it if I had no other option.
Z zgrav Well-known member Sep 14, 2020 #3 Robert said: Technically you could use an A50K dual pot (which Tayda does carry)... bend the second row of pins around and solder them to the first row. Certainly not ideal, but I'd be tempted to do it if I had no other option. Click to expand... interesting suggestion. for that application I would probably use the B25K pot to keep it simple even though it would change the feel of the sweep of the pot.
L lcipher3 Well-known member Sep 14, 2020 #4 Or I could go with the "nature" (W20k) vs separate bass and treble.... not sure if thats better but isnt the original that way? Has anyone done the mod trick to convert linear to log? https://electro-music.com/forum/phpbb-files/pot_taper_amz_168.pdf Also - opinions on the clipping pot? How subtle is it? Last edited: Sep 14, 2020
