Future Project???
Put a PPCB Hyped Fuzz in there and paint it to look like a doomier version of the BOSS FZ-2. Cooler fonts and stuff. At least that’s what I would do with the extra BOSS enclosure. Or make it look like a BOSS Klon.
Do you still have the DC jack from the original PCB? If so, which one is it?
This is going to be Rear In & Out jacks with 12mm Thread Power jack!
It's already been converted to 3PDT true bypass & works with screw locking Boss lid.
Its still going to have Battery access also!
Got One correct 12mm Pot, others Incoming!
They lock into the slot so no rotating pots!
"PRODUCER's SWITCH" — DELUXE EDITION.
IN JACK hard-wired to the OUTJACK.
3PDT switches on/off a RGB LED with the 4 POTS controlling mix of
1) RED
2) GREEN
3) BLUE
4) INTENSITY (overall brightness)
NO labels. ALL-BLACK stock Boss-style knobs.
On the next recording session when the producer says "sound isn't quite right, can you make it more 'bergamot' ?", [or other stupid descriptor]
you turn on the LED, and then play your part again while tweaking one of the knobs until the producer is happy with the tone.
