qak
I'm having a weird problem with the Gerkin fuzz and wondered if it's a problem with the PCB or just me.
Got everything working (or so I thought) and boxed it up, but didn't test the trimpots. Duh.
Then I noticed, that with the CLIP trimpot all the way to the si diode side, it goes silent. So I removed the trimpot, D3 & D4 and changed C8 in case the cap was bad. So I noticed that the space where leg 1 of the trimpot goes is grounded (as well as where the diodes are connected), but otherwise all seems good and continuity checks out ok.
I tried to figure this out for a few hours, but couldn't figure out what is grounding the connection between the diodes and trimpot leg 1. I think there might be a short in the PCB itself.
In the meantime, I lifted leg 1 of the trimpot and soldered the diodes directly from the trimpot to C8 and now the CLIP control works as it should.
