I’ve started using 10k trimmers there for just that reason.Have you played with the values of voltage divider located between Q2 and V-? I usually replace the 470R and 8k2 with a 1k2 and a 7k5, respectively. It doesn’t change the Q2 collector voltage, but it makes the output level much higher, which is how I like that circuit to sound.
I always run a fuzz face at less than full fuzz. It's the only way to have it clean up. Really clean up.It's on breadboard, all the voltages are good, it sounds incredible... it's just fucking quiet. I hate these things. It would be fine if they sounded shitty, but they don't. They're incredible. UGH.
I like this schematic because it includes bias voltages:
I omit the fuzz pot for a 1K resistor, because who actually runs a Fuzz Face at less than max gain? That's what your volume knob is for. I use a 100K output pot, but that isn't the problem - the circuit is a hair below unity gain even coming straight from the output. Replacing R2 with 1K didn't seem to do anything, but I wasn't expecting it to. I use a trimpot in place of R3.
Sounds like bum trannies - ahem, faulty transistors. I've had good success with matched pairs bought on eBay from the usual Ukrainian and Bulgarian suspects.I rebuilt the circuit on the other half of my breadboard again, and it worked after some messing with it. I tried all my transistors by building just the first half of the circuit, and they all work and give the expected amount of boost. In the FF circuit, some of them just don't work - looking at you, AC128s. They were sold as low leakage, but I haven't made a test rig yet and my TC1 never recognizes germanium transistors. I assume it is a leakage problem. Using GT402s with high gain and low leakage is a much better time.
One thing that is puzzling me, though, is that all my voltages are good on the AC128s except the Q1-B voltage. It comes in around -0.045VDC. If I run a very hot signal into it, we get fuzz. What am I missing?
