flippy69 Member Jan 2, 2022 #1 I would like to order a Tayda pre drilled enclosure for the Glory Hole Overdrive but need the "coordinates." This information is included with some of the projects and others not. Does anyone have that information?
Robert Reverse Engineer Jan 2, 2022 #2 Tayda Drill Template - Glory Hole The hole for the LED is sized for a 3mm clear lens (4.4mm), depending on what you plan to use you might want to change that value. Last edited by a moderator: Jan 2, 2022
flippy69 Member Jan 2, 2022 #3 Yes this drill designer is the reason I want the exact measurements, so I can plug them in.
flippy69 Member Jan 2, 2022 #5 Ok great! I think I need to check out the link on computer and not phone thank you!
flippy69 Member Jan 2, 2022 #6 Robert said: Click the link, the coordinates are already there. Click to expand... Awesome! Would you happen to have those for the bootleg overdrive as well??
