Gravitation reverb
steviejr92
Authorized Vendor
Hi guys I’m new to pedal building and this is my 3rd build the gravitation reverb. I had populated the board and I wired it to jacks and stomp switch I had bypass when it’s turned off but when engaged I get no sound even though the led light turns on. Which leads me to believe the problem is on the circuit board yet I have looked at others boards and mine doesn’t look any different I don’t if my parts are low quality if that a thing but all of my polarities on my electrolytic capacitors are right both my ic chips are on correctly, I do use bojack resistors from a kit but I don’t know if that will affect anything I did notice the legs are a bit thinner but others other than that they’re all the right values. I checked my pots and they’re on correctly and I do have the right belton reverb chip soldered directly the only the thing different I could notice was the voltage regulator the pub calls for L78L05 but I have LM78L05ACZ I don’t know if that’s it I read somewhere that the pin out might be different but I’ve gotten 2 different answers yes and no lol. I’m lead to believe this is the problem. Can anyone help me out here I’ve ordered a 2nd board and reverb chip since I feel like the parts could be duds……oh and I forgot to mention because of that confusion about the voltage regulator I’ve removed and tried backwards and the same thing and now I e ruined the eyelets where it’s needs to go idk if it’s salvageable but I’ll be posting pics please help lol
OK, good deal. Now just so we know every other measurement is accurate, put the black lead on ground (sleeve of 1/4" jack will work) and then use the red lead to measure the positive lug of the DC jack again. If you get a similar measurement voltage (near 9V) we can proceed.
Which ever point you chose for ground is what we'll use from this point forward.
Now measure the voltage on each pin of IC1 (the bottom opamp) and list them here.
This is the numbering of the pins, just in case you are unfamiliar.
So I’m getting the same reading when I’m touching jack ground to the power jack but barely anything to the opamps the first opamp slightly less voltage than the 2nd
Opamp2 pins
1- .14 8-.08
2- .14 7- .00
3- .00 6-.00
4- .00 5- .08
I’ve never built this one, so can’t be of much help here. Those experienced with this particular build will no doubt chime in in time. Intuition tells me FWIW that those measurements indicate a problem. Sorry, can’t be of more use here.
yes but not on the pad for the opamps I have no way I touching the pads on the back with out desoldering the reverb module so I’ve been touching legs as my contacts
So this is my jack wired up my out ground jack just recently broke have to resolver that back on lol
