~nick~
here are some brainstorming ideas I've had for a little while. i'm wondering how best to switch between completely separate overdrives yet let all the controls control whatever circuit is active..
how best would you do this with a single switch? perhaps if you controlled which circuit actually gets power that way you can wire each control like a tree root spreading to multiple boards. i imagine this would look like a massive cobweb of wires..
Anyone have any thoughts on this? would having the output of each circuit always connected to the TS jack effect the quality of tone or would i need to cut off the the circuit power AND input/output?
alternatively it'd be nice to have a switch divert the signal.. but that would mean the circuits would all remain juiced to the rails..
the idea: have a metal type, op fuzz, and a OD-BE/Shirley in a single box controlled by the same controls. perhaps even have the option to send one into the other in series. or even parallel for mad scientist tones(though you'd be controlling both circuits simultaneously with the knobs. i bet this setup would be very touchy.
