Pedals that flip phase in a wet/dry rig
JamieJ
Hi everyone!
I’ve just set up a wet dry set up and my quaverato harmonic trem and I think the PPCB Caesar pedal flip the phase which is a pain as the signal is split before modulation. I could run the split after them both but I’d like the separation to two amps.
If I added an inverted op amp buffer on the output of the pedal and before the return to the switch - would this cause any issues? Or I suppose a single SMD JFET buffer would flip phase too and be smaller.
