What exactly am I looking for with the headers for the Electrovibe mini? I see lots of different headers, and can't really figure it out based on the info available via the parts list/screenprinting...
Noted, thank you. I also just realized that the 6-pin male header is for the footswitch. That answers all my questions.I used this:
40 Pin 2.54mm Single Row Pin Header Strip
GTK - Get It Fast - Same Day Shippingwww.taydaelectronics.com
and these:
3 Pin 2.54mm Single Row Female Pin Header
That would be helpful, but I could always do some dry runs to figure it out before I start soldering. Now where the hell can I find a 500R trimpot?...That's correct. If I can I'll open mine up and snap a pic so you can see how the layers stack up.
I'm pretty sure the 3PDT breakout sits below the top PCB, so basically you want to solder the male pinheader to the 3PDT breakout board first with the pins pointing upwards, then drop the top board down on top of them and solder in place.
500 OHM TRIMMER POTENTIOMETER CERMET 1 TURN 3362P
Lead Free - Get It Fast - Same Day Shippingwww.taydaelectronics.com
I completely missed that one. I searched for everything...except the value. Looks like no 250k, though. I never expect to one-stop-shop when it comes to pedal supplies anyway...Thanks again.Oddly some trimpots don't show up in Tayda's search results if you include "trim" or "trimpot" in the query.
Searching for "500 ohm" does it. This applies to several others as well. I wonder how much stuff we're missing in there because of little quirks like this?
Ok. I'll keep that in mind. None of the parts linked in the parts list are in stock, so I have to dig around a bit.25V or higher.
I got this stuff and it measures 11mm...does that mean 11mm of clearance works for this build?I used this:
and these:
I wish Tayda would ship me a paper catalog... I'd pay for it.
Anyone remember Mouser catalogs? I'm pretty sure we lost entire forests because of those things.
