zachlovescoffee
Hello! I have an EHX Small Clone that I am switching out the old positive tip 2.1mm jack for a negative tip Boss style PSA jack. I did the switch and the pedal will power up but I'm getting no signal.
The pedal works in bypass mode with or without power plugged in. But, when I engage the effect, on power plugged in or not, I get nothing. Using my audio probe I am getting signal but it's hard to tell if the effect is engaged.
Could someone take a look at my wiring to see if maybe I have dorked something up? I wasn't sure the 3PDT switch was wired correctly so I re-wired it. I've included pictures showing the original +ve tip wiring, the original 3PDt switch wiring and my finished product. Any help would be greatly appreciated.
