BuddytheReow
Breadboard Baker
More of a general question than anything else. How can I make a pedal louder without using a boost pedal? Can I simply change the pot value for the volume?
It's more complicated than that, and going largely depend on the circuitMore of a general question than anything else. How can I make a pedal louder without using a boost pedal? Can I simply change the pot value for the volume?
I know you said you don’t want to add a boost, but it would definitely help your issue. Take the output of the SD1 into the input of something like the Amentum (EQD Arrows) and just add that knob to your build and it’ll goose it for you.Hmm. Would swapping out the IC do anything or transistors if applicable?
Edit. I just built this and it works fine. Just quiet and I need to keep volume on max and turn my other pedals down for unity.
Boss SD1 Super Distortion
Collection of vero (stripboard) & tagboard layouts for 100s of popular guitar effects, with over 1000 verified designs. DIY your own boutique effects!tagboardeffects.blogspot.com
Would that be possible in this? Wiring is a mess due to vero and trying to figure out multiple wires to one hole.I know you said you don’t want to add a boost, but it would definitely help your issue. Take the output of the SD1 into the input of something like the Amentum (EQD Arrows) and just add that knob to your build and it’ll goose it for you.
I think so. It’s not a complicated circuit at all. You could probably fit it under the footswitch area. You would just need to run the OUT of the SD1 to the IN of the boost. Then the out of the boost to wherever you have the out of your SD1 routed right now.Would that be possible in this? Wiring is a mess due to vero and trying to figure out multiple wires to one hole.
And then swap the volume knob of the sd1 for the other one? Maybe I don’t need to since they’re both 10k, although log vs linearI think so. It’s not a complicated circuit at all. You could probably fit it under the footswitch area. You would just need to run the OUT of the SD1 to the IN of the boost. Then the out of the boost to wherever you have the out of your SD1 routed right now.
You could put a trimmer in place for the SD1 and just dime it, and place the boost’s knob on the outside since it will essentially work fully as a new volume, or you could mount both and find an interplay between the two. It’s worth noting that by pushing more volume out of the pedal, it’ll saturate more. So if you don’t want additional saturation it might not be a fit.And then swap the volume knob of the sd1 for the other one? Maybe I don’t need to since they’re both 10k, although log vs linear
So I need to troubleshoot the circuit? Where would I start if everything “works”?I would think a SD1 would have plenty of output on it's on
