If you use that jack you’ll need to isolate it from the enclosure. It’s best to use plastic jacks seeing how pedals are wired center negative. With this jack the positive sleeve of the jack will short with the metal enclosure. To find the center pin terminal I’d just use your multimeter. It’s most likely going to be the terminal running the opposite direction of the other 2
Thank you. I was sick of using the big plastic ones because you have to solder them pre-installed in the enclosure, but it looks like that's what I should stick with. "too good to be true" is usually correct.
Amazon.com: Shappy 20 Pieces Micro JST PH 2.0 2-Pin Connector Plug Male and 20 Pieces 10 cm Red and Black Silicone Cable Wire with Female Connector: Home Audio & Theater
