How do you install your footswitches ? What to do with the various rings ?
if you are purchasing 3PDT switches that even include a white washer, you need to check yourself.
I'm afraid that this observation is both biased and slightly off the target.
For many pedal builders, some webshop does the part's selection. That's what happens when you order a full kit.
Every 3PDT i ever ordered from musikding came with a plastic washer.
You are free to question Klaus's parts choices, but i never had any issues with the quality of his components. He has all my trust, and never let me down, not once in many years... me and hundreds of other diy pedal builders.
Musikding does an impressive work, they are selling 3PDT with white washers, and these are their standard footswitches for all the stompbox kits.
Now let's have a first exemple of an amazing build with a plastic washer on the outside. In order to enjoy this moment, i decided to start with something not too overhelming, to spare the sceptics and the rebels : Robot_2021-02-25_01.jpg
@p_wats Roboto build.
P_wats is among the most talented artwork designer i've ever seen on this forum.
This isn't a pre-designed artwork from Tayda, or some sticker hastily made on a computer, this is real art. Probably several hours of work.
Have a look at his other builds. Unfortunately, we can't see this kind of artworks everyday in the build report section.
It's hard to put my finger on it, but somehow it would feel a bit strange without the plastic ring. As a matter of fact, p_wats decided to put it on the outside and, in my humble opinion, we should all respect his artistic choice.
Let’s set the record straight.
If you are purchasing 3PDT switches that even include a white washer, you need to check yourself.
I'm checking myself: I use LMS a lot--their basic switch comes with white washer and I think they're great.
That said, I usually replace the washer-unless the pedal is white or has white knobs, in which case the washer looks ok to me.
My tongue was pretty firmly in my cheek there.
Obviously good switches do also come with white washers.
Reactions: spi
Looks like Spi's avatar (a Tube Screamer ?) has a white washer. That's a remarkable commitment to the cause.
Glad you picked the winning side. Today the sceptics have lost a lot of ground. Your reply #183 is very enlightening, the truth will prevail.
Reactions: spi
Hey! Thanks so much for the kind words. Reminds me to finish some builds I've got on the go.
To be honest, my older builds mostly all used the white washers, simply because I had a huge stash of 3PDT switches that came with them. Eventually even places like Tayda have started providing switches with smaller metal washers, so I use those now as a means of letting the paint jobs speak for themselves a bit more. I still have tons of pedals with the white washers installed though!
Whatever you've got on hand is best in my world. Ha
Thank you, brethren. Every week, I used to do a little bit of self-flagellation in that church, to show the Plastic ring my eternal gratitude and my everlasting loyalty. I used 0.5mm2 stranded flexible wires.
Let's have a quick reminder from the Holy Germanium Diode scriptures :
"For the Circuit loves the just
and will not forsake his faithful ones.
Wrongdoers will be "completely" destroyed;
the 3PDT without plastic washer will perish."
Electro-Psalms
and
"A pedal builder may think their own ways are right,
but the White washer weighs the heart."
9VDC proverbs
some m12 metal washers
Also some simple and effective tools, with many different uses ?
For exemple, to cover a hole a bit too big, or to protect a plastic ring from the 3pdt screw.
You will probably be very safe and confortable with these. It can be found sometimes on a rotary switch or some big toggleswitch, but it's not too often.
