moonlightpedalbuilds Well-known member Mar 10, 2020 #1 How do I modify my ReproFuzz for an expression output?
Nostradoomus Well-known member Mar 10, 2020 #2 Expression Control Wiring - PedalPCB Wiki wiki.pedalpcb.com There are considerations to take into account, which pot you are modifying and which model expression pedal you’ve got.
Robert Reverse Engineer Mar 10, 2020 #3 If you want it to behave like the original, use the diagram above with this modification: Replace R16 with a jumper wire on your PCB Replace the wire going from the expression jack to lug 3 of the Treble pot with a 100K resistor
