I’m building a Sabbath distortion
In the reference page on R5 it show under resistor “47” now on the PCB board say in
R5 47p. Is that a regular 47K resistor? Thanks
It says 47R which means 47 ohms (it’s weird I know, but I guess it’s because the symbol for ohm is omega which doesn’t appear on a regular keyboard), same as the build doc says.
Ah ok so is 47ohms not 47K ? Right ?
Correct, 47R is 47 ohm.
That's standard RKM notation. The letter indicates the unit and takes the position of the decimal point.
(4R7 = 4.7Ω, 47R = 47Ω, 4K7 = 4.7KΩ, 4M7 = 4.7MΩ, etc)
Capacitors follow the same system. (2n2 = 2.2nF, 2u2 = 2.2uF, etc)
I avoid the omega symbol for the same reason there are no decimal points in the values printed on the PCB... the silkscreen printer isn't extremely high resolution and it could be mistaken as a 0 if the printing is slightly distorted.
You can type an omega symbol by holding down Alt and entering 234 on the numeric keypad.
Where did you get you bc184? If you got it from tayda then it has a different pinout compared to the board. I learned this the hard way
