I believe this is mandatory for Dust covers on Pots under the PCB.
It is a on going Issue that should be standard practice in Builds.
This stops the PCB from shorting out on the metal back of the Pot :
They come standard with Tayda Alpha 16mm Pots.
UPDATE: Alpha stopped supplying Tayda Pots with Dust Covers on some 16mm Potentiometers.
You need to Order the Dust Cover separately!
5 Cents each!
5 Cents each!
![DustCover for 16mm Potentiometers.jpg DustCover for 16mm Potentiometers.jpg](https://forum.pedalpcb.com/data/attachments/3/3229-70049a30c5668ea7c50d7f48d2ba6f74.jpg)
