Dirty_Boogie
Finished my Mystery Meat this morning... and it's quite tasty!
Fired it up last night, and nothing. Really!? After my first PedalPCB build about 3 years ago, I have a 100% success rate with PedalPCB's, so obviously an operator error. Not having the build docs or schematic to reference, I figured I was in for a rough ride troubleshooting this. Made sense to start with the op amps, as I knew that on each, pin 8 should be close to 9V, and pin 4 should be at ground. Took about 2 minutes to find that on the bottom op amp, no continuity between pin 4 and ground. Pressed down on it, and got signal. Opened it up this morning, and saw that I had missed soldering that one pin... oops
Need to spend more time with it. Expected it to sound a lot like a Klon, but it doesn't. Definitely more dirt on tap, and definitely not transparent, thus my renaming it from "Transparent Overdrive" to "Transparent Overhype". I'm sure I'll find a lot of usable tones out of this thing - just need to spend more time with it this weekend.
