Is this normal on the Parthenon Overdrive
There is not enough space for the B100K potentiometer next to the switch. This is the switch recommended in the build docs so it’s not like I bought the wrong switch or is it just designed to sit crooked like this?
Parthenon Page
Use anything non conductive as long as it doesn't short on any solder joints
You may have forgotten but you'd also want to remove the anti rotation tag from the pot body unless you're going to drill a small hole for it or it won't sit flush in the enclosure
I have an old pair of flush cutters I use to pop those off. Works great. That method would prevent them from flying across the garage, but then what fun would that be?
