i wanted to build a pedal and decided to get the pcb isosceles boost, only problem is i cant get it to work. does anyone see whats wrong? i only get static
Do you have bypass? Your foot switch connections at the board seem frail. Additionally is there a cover on the level pot or could it be grounding against the back of the board?
the volume pot has a rubber cover, i tried resoldering the foot switch cables and it helped slightly. when i out my finger on the switch contacts you can hear the signal and before i resoldered you could get a perfectly clear signal by moving the cables a certain way but now i cant get that to happen
