How would I tie the two pedals together if I only want the gate after boost pedal? I want to have a toggle switch for the gate/ bypass.The order switch PCB will make it so that you can install a noise gate PCB and the boost PCB in the same enclosure and switch between which one is first and which one is second. You could use a foot switch or a toggle switch for the switch PCB.
It’s not that hard, just like anything else, it’s about the time you put in learning a new skill.I think I can squeeze it in, just want to make sure how to wire it up with another 3pdt toggle switch. Dip trace might be out of my ability right now.
… but I do use a gate in some applicationsYou probably would have to build the whole thing again using low profile parts and drilling the holes for the new set up. I don’t think you’ll be able to shoehorn it in there as it is, maybe if you inverted the muffler board so that they face component to it component. It would be much simpler if you would concede to a larger box. Also, if this thing is so noisy for you, perhaps a different circuit is in order. I play very high gain music, and I don’t use a noise gate at all.
