JHS Bonsai / EXAR OD-1
Fizz
I would love to build one of these with a PedalPCB board someday. I'm especially interested in the EXAR OD-1 in it.. that one sounds the best of all the demos of the different pedals in it.
Upvote 2
PedalPCB Little Green Scream Machine Exar OD-1 values
Resistors:
R3 453K
R6 33K
R11 jumper
R12 1M
R14 459R
R15 100K
Capacitors:
C1 47n
C3 100p
C8 47n
C9 1u
C11 100u
C12 omit
Semiconductors:
Q1 BC413
Q2 BC413
U1 AN4558
Pots:
Drive A1M
Tone B22K
Volume B47K
Exar OD-1 Schematic from FSB
There are some niggling differences but you'd be forgiven for building a tube screamer with R6, C1, C3, and drive pot changes only. That's the big difference makers. R6 sets a lower minimum gain, C1 increases the lower range of frequencies let into the circuit, C3 compensates for the larger drive pot that obviously increases maximum gain.
Resistors:
R3 453K
R6 33K
R11 jumper
R12 1M
R14 459R
R15 100K
Capacitors:
C1 47n
C3 100p
C8 47n
C9 1u
C11 100u
C12 omit
Semiconductors:
Q1 BC413
Q2 BC413
U1 AN4558
Pots:
Drive A1M
Tone B22K
Volume B47K
Thanks! So grab the Little Green Scream Machine and sub in these parts? Can I use the NJM4558D from Tayda? I can't seem to find those transistors.. any good subs?
Without regard for transistor pinout, regular transistors like 2n5088 or mpsa18 would be fine. A regular 4558 is fine as well. I was pretty serious in that the suggestions I made are the difference makers. It's more or less a tube screamer so there's no need to be super accurate. JHS certainly isn't swapping all those differences out when you switch modes.
That's good to know as I am a newb. I'll play around with this on a breadboard first and concentrate on those four component changes as I do it.
