The secret for any successful drilling is always the same....
- Use sharp bits of the appropriate type, wood bits vs metal bits isn't the same.
- Use the right speed, for aluminum 200 to 300 rpm is recommended, if you drill with higher speed you risk inducing heat which will melt the aluminum and make it stick to your bit. Using lubricant is also a good idea, but I have never needed it for enclosure at that speed.
- Let the bit do the cutting, don't push it hard thinking it will cut better.
- Make sure you remain inline and straight while drilling (That's where a press drill will be useful).
- If using a press drill, make sure it is set high enough for you to be working near your eye line. My drill is setup with the plate at my chest height to it's lowest and about my chin to it's highest.
- Let the drill get to speed and center itself out before drilling, a wobbly chuck is a recipe for disaster, that's usually when it will bite and try to break your wrist.
- With a drill press, use a good heavy vise to hold the piece you are drilling it, that will save you fingers and a lot of pain.
I'm not a high volume pedal builder like many of you, but I never failed an enclosure drilling and I'm using a very humble medium quality press drill (about 16 year old)....
