drew.spriggs
Howdy,
Built a King Nothing. Everything works fine, voltages are spot on (254v on the plate resistors, and 29v heading into the J201), but there's significant amounts of oscillation that decreases as the gain is turned up. Low switch has no impact on the noise, but the left position of the mode decreases the range where it oscillates from about 1-9 to 1-3 (assuming each tick is about 30 degrees of rotation).
I've tried multiple power supplies, from isolated DC bricks, to cheap SMPS to an old unregulated power supply I've got around (all capable of +500ma), and no difference. Tried multiple guitars, multiple leads, etc and there is no difference.
Tube is a brand new Shuguang 7021 (confirmed to be good), J201 is a onSemi MMBFJ201 on a SOT23>T092 adapter board.
Thoughts?
Thoughts?
