Kliche Mini Fail
swelchy
First build is a fail I ordered a second pcb and still waiting on tayda to ship to start over. Still trying to figure out what i did wrong. First off I used 1/8 W resistors... next build i ordered 1/4 w. I'm pretty sure i have my switch wired wrong... I get no signal with pedal on or off... just buzzing... The pedal pcb wiring diagram is a bit different than my board.. the in and out on the pcb is in a different place. I used a break out board and used the numbers on it to coincide with what diagram said... 321456 on the breakout were wired from left to right like the pcb shows...
I’m not sure that switch board is compatible with the kliche. The kliche has a buffer, so the routing on the switch pcb you’ve used would not match. I believe pedal pcb makes a kliche specific foot switch board. Aside from that, the soldering here looks a little suspect, unless you’re using lead free solder
yes... lead free solder. these are really my first few months of messing with soldering properly. I bought a Merece st-2090
d soldering station... I also ordered the kliche breakout board with the new pcb on the way
Also... another mistake I just found that I used D9 russian diodes and they have the stripe on the opposite side.. i have them in backwards...doh
My second attempt has failed... I still have never built a working pedal. This time I get no led... No signal with switch pushed in and out. This one is just completely dead... the last one I at least got squeeling..lol No idea whats going on... I just tried re wiring my dc jack to see if I had it backwards.
Check the Attached picture below to check for missing solder to pads!
Can you take it out of the enclosure & see if you get any Sound out of it in Bypass & On position'
Looks like 1n4007 diodes instead of 1n4001, I don't know enough to know if that would make a difference, so wait until others chime in before you start desoldering. Also, do you have any type of insulation between the pot and PCB?
I have the plastic protection covers
on backs of pots.... The 4007 should be fine.. just a higher reverse current protection from what i read and i already had them
checked out of enclosure... no signal...no bypass signal no led... I reflowed the joints in question... the pads were fine on opposite side of board but i flowed them anyways... a fb group said its possible my breakout board could be issue if i flowed too much solder and bridged from the unseen side... makes sense... going to look there next.... i did flow a lot of solder to fill the giant holes
You could have damaged the Footswitch also if you applied to much Heat.
You need to wait between Pads & never solder next to the one you just soldered in up or below position!
Do it in 2 passes !!!, Solder HALF, Finish second time around!
