Robert
Reverse Engineer
Yep, that's the one.
Part numbers are listed in the v1 build docs.:
Exactly the kind of content I come to these forums for! Thank you.Cathode was derived from the Greek word "kathodos": https://en.wikipedia.org/wiki/Cathode#Etymology
That’s right. The stripe on the diode pad indicates the negative (cathode) end. If the legs on your LED are clipped you can tell the negative side still by the flat portion right where the legs attach to the epoxy. Generally you’ll want to experiment with the clipping diode sections of the circuit...don’t replace the 1n5817 with an LED![]()
