LEDs to DPDT Question
VanWhy
For the Acetylene Overdrive, I like the original pedal has an LED lit for either side of the headroom switch when selected. Is it possible to add this to the DPDT switch that gets installed on the board? Is it as simple as Cathode of LED to end lug, anode (with CLR) to 9V? And vice versa on the other side. Or is this not possible with a DPDT on this circuit?
Yep. Use common anode and always switch ground.
That said, one side of that switch(A side) toggles ground so you may be able to incorporate a bicolor led on that leg. It may introduce popping, not sure.
