SOLVED Leprechaun - Spectrum pot not doing anything
Cenotaph
Hello,
I recently got a kit for the Leprechaun (from Musikding.de, if that matters). I assembled it and generally it seems to work, but apparently the Spectrum pot (the one that controls pitch) doesn't do anything. The sound from the pedal always seems to be a third above, so it should be the setting with the pot fully turned up. So far I tried to resolder the lugs from the pot, but without success. I added a picture of the pcb below.
Any help greatly appreciated - thanks in advance!
If you aren't going to use an expression jack you need to install a jumper from the T pad to the pad directly below it.
See the wiring diagram on page 5 of the build docs.
