DGWVI
- Build Rating
- 5.00 star(s)
To sate my own curiosity and desire to constantly build stuff, I recently whipped up a bunch of Rat variants. Didn't go heavy on the mods, but I'll note what changes I've made to each one.
First up, the rat0log (Triad Distortion).
I decided to replace the diodes with Nanolog N2 and N3 clipping devices, and use an on/off/on toggle for a total of three options. The Nanologs aren't made anymore, but they're interesting things. The N2 is their equivalent to typical silicon diodes, while the N3 is their answer to LEDs. They both offer a much more gradual response than the traditional equivalents. Some have said tube-like, and I can't speak on that, but they do sound great and have a wide dynamic swing.
The only other tweak to this one is I replaced the 560r with a 470 for a smidge more gain and tightness in the low-end. ECG938 metal can for the mojo
Next, is the Pandora's Box
I opted for infrared LEDs for the clipping to give it more play on the response. ECG938, and 560r replaced with 470 as above
Dingo
No tweaks to this one, other than using a 2N7000, as those are the only MosFETS I keep stocked. D9V for the germanium. ECG938 used
rat basstard (Frajeelay)
I have this one and on/off/on toggle, and moved the LEDs (infrared) to the center position, so it's got Germanium (D9K), LED, and silicon clipping options. ECG938, and 560r replaced with 470.
I've also modified the clean buffer section into a boost to bolster the versatility
Dingo
